Hi All
Installing a 2nd CU in a garage, the garage is currently fed by a 4mm t&e cable (overhead) direct from the cu in the house protected by a 32A mcb. I've been asked to replace this with a SWA to go under the new path, I intend to install a Wylex board with a 63A 30ma RCD incomer, 6A mcb lights, 16A mcb socket. The bit I'm unsure about is the customer requires a further feed to a second detached garage, I intend to run about 25mtrs of 4mm swa from the new cu to a double pole switch then a 2 gang socket and then a fcu and switch for a florescent fitting. The customer has said he might want to add an electric gate which would be attached to this garage. Would it be OK to protect this circuit with a 20A mcb or should I fit a 32A in case of the additional loading at a later date
Regards
PAD66
Regards
PAD66
