Discuss Garage conversion to habitable space in the The Welcome Forum area at ElectriciansForums.net
gaz
Hi
I have a garage that I'm converting in to habitable space
I will have electric shower, oven and hob, 2 x electric heaters, microwave, kettle, tv and lights
The cable run from the consumer unit (C/U) is 13-15 meters
What size armoured cable should I use? and what size mcb rating at the C/U
Welcome to the forum mate.
These are new circuit, so depending on where you live within the UK, will be part p notifiable work.
Also, I presume you will want this at least to be checked by an electrician, so you get a cert for it. In this case please consult the electrician who will be putting their name to this cert. They will tell you all the info you need.
Hi
as a starting point, i'd be looking at 16mm cable on a 63A breaker, but get a sparks in to verify.there are various factors to consider before deciding.
Thanks telecrix, that's great for a starting point :)
When you say "various factors" could you give me example please?
volt drop, installation method, actual load.
Reply to Garage conversion to habitable space in the The Welcome Forum area at ElectriciansForums.net
