- Reaction score
- 51
Hi, after some advice on garage door wiring, know someone who’s having an electric garage door fitted, I presume it’s just fitting a switched spur and then garage lads will do the rest?
Discuss Garage door wiring kit in the Electrical Forum area at ElectriciansForums.net
Thanks will do, only info I have is they need a supply, I’ll get customer to call as I have seen some that just require a socket outlet so plug and play.Usually.
However, probably quicker just giving the garage door company a call. Maybe included in the quote that they install an FCU for the unit.
Good shout, I’ll check thanks, there is 2 ways in through garage door, or door, cheersSome just require a socket-outlet. They may also require an unprotected way, no RCD, if there's no other access door into the garage.
Ooooo sounds rough, not good when your spending nearly £1000 possibly more, I’ve had a quick google and yes I’ve seen a couple on requiring a socket outlet but I’ll check with them to see they need.Hi,quite a few,now only require a socket outlet,to simplify the fitting process,but any of this size,would probably be neater with the switched spur (neon is a good idea)
Door fitting outfit should have their requirement listed,electrically speaking.
Hopefully,they are more professional,than the team who "nailed" me pals,on. They used mechanical expansion bolts,in the feature quoins,at the rebate...and burst most of them £600 to replace them,then the same set of fools,turned up again,but this time,they were going to use brown rawlplugs,in the joints and expanding foam
.....they won't be returning...
That makes no sense, the amount of access available has no bearing on the requirement for RCD.
If an RCD tripping will trap someone in the garage then so will the MCB tripping or a power cut, so that idea is void.
I've seen it on one manufacturers instructions therefore I thought it was worth a mention as most people tend to ignore them anyway.That makes no sense, the amount of access available has no bearing on the requirement for RCD.
The only reason I could see them including this in manufacturers instructions is if the mechanism uses an invertor or electronics that would nuisance trip an RCD. However the circuit would still have to be installed to comply with all the regs needed to negate RCD protection.
Reply to Garage door wiring kit in the Electrical Forum area at ElectriciansForums.net
