Discuss Garage supply runs from my neighbours house..... in the DIY Electrical Advice area at ElectriciansForums.net
Hi, looking for some advice please,
My garage electricity supply runs from my neighbours house, the supply has its own metre which i pay for ...recently he has threatened to turn the supply off....
I need to know, a) is this legal and b) how do i reroute the power from his house to a mains supply.. ?
Any advice will be very helpful..
Tommy
Was this existing when you purchased the house or something agreed later?
if the property is rented, then push the problem to the landlord.
Any formal agreement in the house purchase documents?
the survey should have picked it up and if the solicitor did nothing about it, there may be some claim you can make To cover the costs involved.
Can you route a cable directly from your house to the garage, or does it have to cross your neighbours property?
Do you actually need electricity in the garage?
If they are being difficult, best get it changed or it will always be a threat they can use against you
i pay the neighbour... the garage has its seperate metre and i pay monthly the amount that is used...
Ahh, in that case unless you have a contract that states the terms of supply and availability you are pretty much screwed.
best option, if possible, would be to supply the garage from your own house.
Reply to Garage supply runs from my neighbours house..... in the DIY Electrical Advice area at ElectriciansForums.net
Hi all, I recently moved to an older property that had a run down garage. We had this removed and a summer house put up in its place. The old...
Hi everyone, I intend to bury a 240 volt cable from my house to my barn about 7 metres as way. It will be buried under my tarmaced drive which I...
Hi I have a Corby 7700 trouser press it is a 220w model, 3 years 10 month old. On Friday it stopped working, so I took it to the garage ready...
I’m planning to run an electrical sub-panel to my detached garage (about 150’ away) and run it off my 200 amp home panel. I live out in the...
My house is a small 3 / 2 with an attached garage. Recently a new circuit was added to install 2 new ceiling fans in the patio. Can I use the same...
