Discuss Garage wiring in the DIY Electrical Advice area at ElectriciansForums.net
I would keep the metal conduit - if you need new bends made up I can probably help out - PM me. I'm based not far from Brighton.
Reply to Garage wiring in the DIY Electrical Advice area at ElectriciansForums.net
I need to run a electric wire from the garage to outside against the house and back into the kitchen for a stove can I just use a outdoor wire and...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
I’m planning to run an electrical sub-panel to my detached garage (about 150’ away) and run it off my 200 amp home panel. I live out in the...
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
