Discuss Gas Bonding to MET or consumer unit in the The Welcome Forum area at ElectriciansForums.net
sorry if this has been covered but I cannot find answers -
1st floor flat TNS supply from basement - the water is bonded at the stop cock within the flat to the consumer unit .
The Gas enters in 2 places for cooker and boiler . Some "brightspark" has earthed this via a rod at the meter - does the bonding need to go back to the MET in basement or is to the C/Unit ok ?
Hi - if the flat’s water is bonded to the flat’s CU from where it enters the flat, I’d do the same for the gas. I understand 2 gas pipes are entering the flat, so I’d bond both. If I’ve understood correctly the gas supply to the building has been put to a rod? I’d probably bond that gas pipe to building MET in the basement.
Reply to Gas Bonding to MET or consumer unit in the The Welcome Forum area at ElectriciansForums.net
Hi, went to have a look at a job today, customer has had gas supply company out (for another issue) and they have commented that the protective...
Did a eicr on a upstairs flat, there is 1 main bonding cable from the consumer unit, the gas pipe comes from the gas meter outside and up the wall...
Hello wise electricians of the world! I am in the UK. Recently we had a water leak which caused some damage in our home, we are currently trying...
4K
This is a question (or discussion probably) regarding selecting the main earthing conductor, and subsequently the main equipotential bonding...
6K
