Discuss Gauge Speaker Wires: Clueless in the UK Electrical Forum area at ElectriciansForums.net
Hi
Sorry if I’m posting in the wrong forum I had a look on the search tool but couldn’t find a definitive answer to my query.
A relative of mine has 4 speakers inbuilt into their ceiling (see pic) and 6 gauge speaker wires (see pic) coming out of a wall panel.
None of us know exactly how to connect it together. I have seen small affordable amps online however they only seem to have one left audio input and one right audio input, but there’s 6 speaker cables? Does anyone know which amp would work?
Also, would they need to put F heads on the end of the speaker cables, or Banana connector heads to plug into the amp?
From the amp to the tv which wire would they need?
Apologies if this is basic but we are all pretty much novices in the electrical world
Hope someone can help!
I'm no expert, but a lot of domestic speaker cables are simply pushed into a spring clip connector on the back of the amp.
From TV to amp you could use the red and white phono plugs, or alternatively an HDMI cable or optical link.
It all depends on what outputs the tv has and what inputs the amp has.
Hopefully, as this is a domestic installation, rather than for BGM/announcements in a commercial application, these will be low impedance units.... otherwise the lack of much happening sub 200Hz at such close listening proximity would tire on the ear.
How are the speakers arranged on the ceiling? It could be that they are intended to be used as a surround sound set up, in which case you'd need a special amplifier with multiple outputs.
If not and they are just designed to be stereo left and right, you may be able to connect multiple speakers in to the left and right outputs of a stereo amp.
A photo of the connections on the back of the television would help with figuring how to connect this to an amp.
Are there six speaker cables in the photo? If so, do you know where the other two speakers are?
Reply to Gauge Speaker Wires: Clueless in the UK Electrical Forum area at ElectriciansForums.net
Firstly, I hope it is ok to discuss the wiring of speakers here. TBH my ignorance in all things electrical knows no bounds, and I am guessing it...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
I have a breaker that keeps popping when we turn on the Christmas lights. I know the lights don’t have much draw however they are on the same...
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
Ok so live in 89 mobile home ugh I really need lots of work but I'm on disability and I cannot afford electrician but I've been working with all...
