Snips
Hi this is the first time I've posted
Probably a daft question but I have aver been asked to wire up an industrial wood chipper which is rated at 125kva from a 150kva generator. I will cable from the control panel to the motor in 25mm 4core but what should be used for between the generator and the panel.
thanks this is the first time using a generator as a supply and unfamiliar with it
