Discuss Generator light problem in my 65 Buick in the Auto Electrician Forum area at ElectriciansForums.net
doogie
Hey guys, I'm new to the site as I'm experiencing a problem with my electrical system in my 65 Buick Sportwagon. This is what I did. The car was charging fine but at idle the light would flicker and the GEN light would lightly glow, which would go out once I gave it gas. So I took out the alternator and took it to test it. It tested fine, but in the process I saw it had terminal on the back that was not hooked up labeled GND. So I put it back and ran a ground wire to the battery. I thought I fixed the problem because no more light flickering. Until....
The GEN light does not come on when I turn key to ON position. It does comes on when key is in ACC position and when I turn the key to the START position. Also, I took the belt off the alternator and ran the engine to see if it would trigger the light to come on and the GEN light still does not come on. I have no idea what to check or what running a ground wire to the battery might have done. The car does have a voltage regulator in addition to the alternator. Any help would be greatly appreciated. Thanks
Hi Doogie and welcome along to the forum.
Hi dude,this system sounds similar to some of the older british trucks,which had alternators with external mounted regulators.
Does the charge warning light wire,go to this? It is also worth checking you have the wiring correct to the ignition switch.
There should be an ignition live to ignition circuit,whilst at start position,or it would not fire,so it is strange this provides a different state of charge light illumination.
If you can list terminal nomenclature,on both alternator and regulator,i may dig out me old notes on such antiquated yokes.
I had them dusted off a while ago,for setting up a current/voltage regulator,for a dynamo on a Fergie tractor.
Any muppet can drive an ipad...but it takes bear grylls to stone cut-out contact,and flash field coils...:smiley2:
Reply to Generator light problem in my 65 Buick in the Auto Electrician Forum area at ElectriciansForums.net
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
I have a 1986 diesel van. I (foolishly i now believe) upgraded to a 150amp alternator. Recently, i was driving and when I turned the van of, it...
Hello all, I have a tail light for a '12 Ducati Panigale 1199 S, that I can't get working properly. The brake light / daytime running lights...
Good evening all Ive got an old truck 1990 that has always had intermittent starting issues whilst ive owned it.. As far as i am aware the...
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
