Discuss Getting into a resin filled joint in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi all,
Couldn't find existing thread on this.
Need to get into a large resin filled joint on a 120mm 4 core SWA and wanted to know if there was a solution to dissolve it or is it a case of hammer and chisel like the old days. It is a cold cured, two part resin Kit from CTC.
Any help appreciated.
Mick
A stab in the dark, but how about a blow lamp???
Might be a bad idea mate. Depends on melting temp and what the resin is made of. If there is little air pockets in it, like cement, then it could explode a bit.
Wear the correct PPE and you should be OK
Do you actually need to dissect the joint? Is there a space restriction etc? If not 2 joints and a piece of cable to allow the joint to cut out would be easier and the time saved would pay for the extra joint.
Assuming it's some kinda cross linked polyethylene you do get a conformal coatings strippers which is basically a polar solvent as far as I know so MEK or acetone should work. The solvents aren't pleasant to work with and are carcinogenic so use appropriate PPC. Also it's likely to take time....lots of time, I've un-potted smaller things in the past like control boards and solvent penetration is very slow, it's taken days of soaking and agitating. Solvents are also likely to destroy the original cable insulation so as already suggested above you'd probably be better remaking entirely with 2 joints or even the hammer and chisel as you mentioned in the OP.
Reply to Getting into a resin filled joint in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, we need to joint several 95mm² 4 core SWA cables, the joints kit are Prysmian JST Low Voltage Universal Cable Joints and are supplied with...
Hello, So I'm an idiot homeowner who has enough knowledge to be dangerous.. I tried to make my own shortcut by tinkering and I seem to just be...
Hi I have been in the electrical contracting industry all my working life 40 years and became a member of the NICEIC in 2006. During this time I...
Hi there. I'm building a house and need some help with the LED lighting design. Lots of experience wiring things, some experience using LEDs (did...
I have a repair job coming up - a garden has had 240V lights fitted, with which the junction boxes have been filled with magic gel - they haven't...
10K
