Discuss GFCI issue in the UK Electrical Forum area at ElectriciansForums.net
I have a garage refrigerator that immediately trips GFCI when plugged directly into GFCI. If I use a heavy ext cord it does not trip. If I move fridge to another outlet fed off of a remotely located GFCI, that one does not trip either. It seems to be fridge related. But no issue when more wire is between GFCI and fridge. GFCI is new(replaced) and no other test device trips it. Home is modern)2004) with modern wiring. Worked for years and one day this issue began. Any ideas? Thank you.
When you are running the fridge off the extension cord, is it still connected to the same GFCI at the board, or is it on a different circuit? If it is cumulative leakage causing the tripping, moving it onto a different circuit may be why it does not then trip.
In the US The fridge is supposed to be on a isolated 20 amp circuit and it doesn’t have to be GFCI. The reason it trips is when the compressor kicks on.
What ratings do you use in America
I read somewhere the standard ground fault circuit breaker is 10milli amp which would be seriously prone to nuisance tripping
Cap I can’t really tell you what to do except that in your HOME the refrigerator In the kitchen does not have to be GFIC. now we are talking about GARAGES which all receptacles have to be GFCI protected.
Reply to GFCI issue in the UK Electrical Forum area at ElectriciansForums.net
I have a small power washer with a two-wire cord and GFCI plug. My outdoor and garage receptacles are on a "house GFCI" circuit, wired in series...
I recently rewired my laundry room with MC cable, 20 amp circuit. I installed an AFCI/GFCI combo switch. The gas dryer trips it as soon as I plug...
GFCI green light is lit when not under power draw. The bidet seat functioning causes light to pulse yellow (and creates a pulsing and knocking...
Hello all! Newer house, original owner(Florida). no change to electrical system. Just found there was an outlet (GFCI) in the closet so I wanted...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
