- Reaction score
- 0
I wired my garage this summer. Installed panel, laced it in. 24 circuits. Over 200 plugs lights ect. No issues. It all works fine
Except 1 circuit. 15 amp runs from panel to 1 gfi. Loads out to basic 15 amp plug. From there to gfi number 2 in the bathroom. In on the line terminals of course. Load out to 1 more basic 15 amp plug , then off to run a switched fan.
When I power up circuit, gfi 1 trips. Never the breaker. I remove gfi 1 then either direct connect the hot/neutral in the box or install a basic plug in the gfi 1 box. No problems. Circuit works great. Gfi 2 never trips. Loads out to plug and switched fan fine. Put any gfi back into gfi 1 location, gfi trips. Never the breaker.
Any ideas? I could always just marett the hot/neutral in gfi box 1 and put a full cover on it and call it a junction box as it's not really needed but I am puzzled and would like to find out what's going on. Tested all plugs with a neutral short to ground, ohm test plug in tool. Get ok on every plug
