Discuss good joist drill? in the Electrical Tools and Products area at ElectriciansForums.net
super spark
Can anyone recommend a good joist driller?
Purchased many drills in my time & still I am unsure to what joist drills to supply my lads with. Tried the angle makita's & they were useless.
any ideas???????:(
I swear buy the irwin auger wood bits they do all the work for you i would never use flat wood bits again ,never used any kind of angle bits though .
Augers are good but get balls up when you hit an un-foreseen nail...........
thanks for the comment, will have a look. was looking more for what machine you use rather than the bit though
Reply to good joist drill? in the Electrical Tools and Products area at ElectriciansForums.net
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
So I had a ceiling repair done in my bathroom due to water damage. The neighbors toilet above me was leaking for who knows how long. Mold...
Most of the work I do is additions and alterations in domestic properties, and other than swapping accessories and lights in new-builds for...
