- Reaction score
- 17,092
You need a video??Any videos on how to do this?
Discuss Good practice in the UK Electrical Forum area at ElectriciansForums.net
I have been wrapping tails for years it prevents the conductors shifting. This is a 35mm bond I recently did, wrapped and you can see there is no shift and that is as tight as it goes.View attachment 55570
OK Thanks why not Westward's pic shows a clamp not a screwed terminal connection!Conductors fixed in screw terminals shouldn't be tinned.
Nothing fancy about it Mate just good professional practiceThat's a nice job, I would have used a ring crimp if possible.
mainly because I don't have the patience to do all the fancy work as shown above!!
[automerge]1580844638[/automerge]
Then we will have to disagree on this occasion mate. nothing personal.True. I must admit I was referring to not tinning when the wire was directly under a terminal screw, which should not be done. This is slightly different although the principle I think is the same.
What was/is there to be pulled up on Mate, the people that ,make the rules are all seeing Engineers, aren't they???? or supposed to be. Gods to be obeyed no less.While on the topic , old fuse boards the main switch terminals were rounds and accepted the tail a nice fit with twin screws...
now today the tails core is still round (ish) but the cage terminal is square
was this never pulled up upon ??
You need a video??
Have you not had any experience, of soldering??? tinning is covering the copper with a thin layer of solder, thus sweating the cores together to put it simply, google soldering or tinnimg conductors may show you more than a difficult written instruction.Yes. Or some kind of instruction of method
If he has a trainee banner then he may not be as experienced as older more seasoned electricians on this forum on different methods of terminations so I don’t understand the double question marks as if he should automatically know this method.You need a video??
Basic soldering should be a skill most Electricians, Trainees or Apprentices should posses in fact most DIYers have soldering skills, plumber do!!If he has a trainee banner then he may not be as experienced as older more seasoned electricians on this forum on different methods of terminations so I don’t understand the double question marks as if he should automatically know this method.
I can count on one hand the amount of times I’ve soldered, it’s not that common Pete depending on your scope of workBasic soldering should be a skill most Electricians, Trainees or Apprentices should posses in fact most DIYers have soldering skills, plumber do!!
Reply to Good practice in the UK Electrical Forum area at ElectriciansForums.net
