Discuss Grafik Eye Lighting Fault in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Does anyone have experience working on these Grafik Eye Lighting Systems? Not 100% sure how they work. By the looks of it, its LV switching mains voltage lights? The main controller is now dead, all LEDs are out and as a result all of the lighting associated with that controller is now out too. Replacement controller is £450.00. My plan is to replace this fancy controller with four good old fashioned dimmer switches. One for each zone. WILL THIS WORK, I wonder?
Any help would be much appreciated before I blow something/someone up :)
**Whenever you see a man helping his wife out of the car, its either a new wife or a new car** ;)
you should have a feed (perm L and N)
and then a SF.L+N off to each zone of lights
so this can quite easily be turned into traditional toggle dimmer switch as you would usually 2plate lighting
Reply to Grafik Eye Lighting Fault in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi all, I'm wondering if anyone might be able to help. We have a fused switch that controls 4 LED lights next to a power socket which have both...
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
