Discuss GRANDFATHERS old-style scooped forced air torpedo heater sentimental value! in the DIY Electrical Advice area at ElectriciansForums.net
Recently had this part burnt out . I have tried to contact numerous parts people, companies, and diffthat didn't
Can you post a couple of photos for us to see the part...and the heater?
I can't be certain because I've not been able to find anything about that burner due to it's age. It could be it's something to do with the photocell flame detection (no light, turn on the igniter kind of deal). The best thing you could do is have a chat with a local plumber who deals with heating, particularly oil burners.
I know what a lot of the components are in that burner and how they tie together but I have no clue what that block does beyond the possibility that it's something to do with the igniter (if you're not familiar with these burners, the igniter transformer can be lethal so be very careful around the spring terminals/copper contacts coming out of the block on top of the blower and never touch them when the power is applied).
Being American, it could be anything! ?
Thank you for your opinion. I thought the blk block was a solid relay but I'm not sure tho.
I'd suggest contact the manufacturers for advice.
They have a downloads page and if you scroll down they have pdf's on models going back to the 1960's so with a bit of luck and patience you might find some relevant info. Good luck.
Thank you for tha advice! The spot on thats black block where the info was where it burnt up at. I was wondering if anyone knows anything about solid state relays? Could this block be one? Also Thank you for all your time i do really appreciate it!
I have they said that model was soooo old then tried to sell me super expensive unit. I responded to then saying all I need is part number or volts/ amps requirements however I'm still waiting on return email 2 1/2 months now.?
This is what I have to go off of. Thank to all who has helped its very appreciated!
What part would be responsible for when shut down the fans keep running till thee unit cools down. Only reset button on the unit is on electrical motor.
Wow I do appreciate all your time and energy everyone has put in on my issue!!!!. Y'all are great people.
Reply to GRANDFATHERS old-style scooped forced air torpedo heater sentimental value! in the DIY Electrical Advice area at ElectriciansForums.net
Hi. I'm having an issue with an old style storage heater. A workman disconnected the storage heater to lay new flooring under it . For some...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Forgive me, for all my terminology is going to be wrong here. My home has an old fuse box that handles a small section of the house. They take the...
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
