Discuss Ground wire and gfci breaker in the Electrical Forum area at ElectriciansForums.net
You terminate your ground wire on the ground bar in the panelI’m adding a 20 amp gfci circuit using 12/2 awg wire. What do yo do with the ground wire when wiring the gfci breaker?
Thanks. I guess it’s not mentioned because it concerns grounding the outlet not the actual circuitYou terminate your ground wire on the ground bar in the panel
The outlet needs grounding alsoThanks. I guess it’s not mentioned because it concerns grounding the outlet not the actual circuit
Reply to Ground wire and gfci breaker in the Electrical Forum area at ElectriciansForums.net
