Discuss Grounding resistence in the UK Electrical Forum area at ElectriciansForums.net
Am I missing something?
I ve been fighting this battle for years.
A customer keeps telling me I have to measure resistance to ground in the panel(main ground conductor), I say for consistency I need a proceedure, they come back with use the clamp meter, hanging the clamp on the ground wire. My arguement is that the clamp does not measure resistance(only the probes) so any readings they ve picked up are false.
Am I wrong?
Sounds correct to me, as far as I know you can only measure current flowing to earth under fault conditions with a clamp meter.
You really need a dedicated earth loop tester. I don't know what people use in Vancouver but here in the UK we generally have multi-function testers which include this functionality. Separate loop testers are also available.
Am I wrong?
As far as reading resistance we have started using 2 ground rods to get the resistance that we need and it’s not a requirement that we actually need to measure resistance but we are looking for 23 ohms or less
Reply to Grounding resistence in the UK Electrical Forum area at ElectriciansForums.net
Now I understand why so many people in US have stories of computers blowing up during thunder storms. This is a pretty dumb rule for ground...
I am a complete novice when it comes to electrics but I have recently bought a grounding mat and so I've been doing some measurements and I'm...
Hello, I had an electrician install a 100Amp subpanel which feeds a mini split. I addition I added a Homeline 50A GFCI breaker to power a shed. I...
Brian, DIY but 30-year commercial/industrial master HVAC tech. I have installed an emergency whole-house breaker switch next to my service...
Can someone tell me what the resistance should be for a Solar iboost Clamp? My clamp is regestering zero ohms and I want to confirm this is the...
4Dave C
