Discuss Guides for ground mounted systems? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Scott H
Hi All,
Anyone have any guidelines for ground mounted systems - most of what I can find is for flat roofs rather than installations in someones garden.
Trying to find things answers to things like:
  • do I need steel armoured DC cable?
  • earthing of array?
  • DC isolator next to array in housing or inside the house next to inverter? (or both?)
Thanks for help in advance :)
Scott
DC cable in ground. Say from array to inverter a distance away. Yes SWA is good practice. Calculated value to less than 1% VD.
Earthing array. Same old question. See DTI Guide and make your choice dependent on inverter.
DC isolators. BOTH ends. Array & Inverter is my opinion. Also gives you some way of terminating the DC-SWA at the array end.
Also Sibert now do a DC Isolator prewired with MC4's in and out - makes install a bit easier.
(You could question wether it should be so easy to unplug the cable, however most inverters have DC plugs that are readily accesible anyway...)
Reply to Guides for ground mounted systems? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Hello there I have just installed a new Solis S6-GR1P3.6K-M-DC Inverter - this replaced a 10 year old+ Sungrow inverter that failed/out of...
Hello All, Currently building an extension to my barn/workshop and before i pour the foundations i want to run some new cables from my ground...
