Discuss Gym with lighting over 4/5 circuits and 2 mains in the Lighting Forum area at ElectriciansForums.net
Webby
Hello,
currently working on a gym with 4/5 lighting circuits across two mains boards
I’m wanting to put some emergency lighting in there and I’m wondering how I do that with this number of circuits across different rcds
thanks in advance
EMs should be supplied from the same circuit/s as the local lighting, so i would be looking at wiring each EM (or group of EMs) to it's local circuit. depends on how the circuits are wired as to how you do this.
That looks a complicated area to install emergency lighting. Do you have a copy of BS5266:1
I see there is at least one self contained bulkhead in place. It is difficult to see from the pic but if the existing battens are wired through conduit I would fit led emergency battens to replace the existing as should be easy enough to rewire a permanent live. If aesthetics are important it wouldn't be a huge cost to replace the lot, some em and some standard. Might be an idea to get third party design so lux levels are correct and to provide photometric data.
Reply to Gym with lighting over 4/5 circuits and 2 mains in the Lighting Forum area at ElectriciansForums.net
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi, I have run some outside lighting for a customer in Hi-tuff cable. He now wants 2 additional lights run across scaffolding which has been put...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
