Discuss H05RR-F/3183TRS to Outside Lights in the UK Electrical Forum area at ElectriciansForums.net
Good afternoon all,
I’ve got to fit 2x 20w LED Floodlights this week and just wanted a sanity check before I start.
There’s one light up already supplied from the upstairs RFC via a double pole SFCU. Supply goes out into the back of a wiska box which the pre-installed flex of the light glands into. I’m going to take my supply from there and clip the cable neatly under a step in the brickwork round to a small wiska box beside each new light.
I’ve got a reel of cable I was planning on using (can’t for the life of me remember what I bought it for). It’s black 1.5mm 3-core H05RR-F (with 3183TRS also written on the label).
After a few searches online I’ve found it’s the tough rubber sheath rubber variety, but just wanted to double check whether you think it’s suitable for use on this job?
If it’s not, could you suggest an alternative? Obviously haven’t got a problem getting some different cable - it just makes the job a bit more profitable if I use what I’ve already got!
Thanks in advance!
Reply to H05RR-F/3183TRS to Outside Lights in the UK Electrical Forum area at ElectriciansForums.net
First post so go easy on me. i am a competent DIY’er, just after some advice. Apologise if the terminology isn’t spot on! my house was rewired two...
Hi guys, long time lurker first time poster. I have an SWA 3 core armoured cable buried that runs to my back garden. This originally serviced an...
My garden lighting was tripping my MCB so I checked all the junction boxes outside. I disconnected the live, neutral and earth connections in...
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
Hi, I’m new to the forum and am seeking some advice please. I’ve picked up a job that another electrician has abandoned, the job is to...
