Discuss Handyman and Electrical Work in the UK Electrical Forum area at ElectriciansForums.net
I recently started up my own handyman business and wondered what I am allowed to do in terms of electrical work in customers houses. The sort of thing I am talking about is changing mains sockets, light fittings, light switches, extending existing ring mains... I know that for work in bathrooms and kitchens the work has to be checked out by a registered sparky. I feel I am pretty competant and safe when it comes to electrical work, having been an electrical / electronic tradesman in the forces and done loads of DIY work on my own house.
Would I have to provide a Minor Works Certificate for any electrical work I did?
Thanks for any info.
Do you have any test equipment? A copy of BS 7671 AMD3?
EDIT: Part P doesn't apply in Scotland
If you have added or altered an EXISTING circuit the answer is yes. I do voluntary work as a Handy Man for AgeUK I won't touch electrics, soley because their insurance won't cover me.
So many varieties
You should know Mate, you have been recomending pocorn a lot lately, best try some Vindaloo for your sore B-m, only you will understand that one, any good films on at Sixfields worth watching?
Hi Ian and Welcome to the Forum !
Perhaps something to investigate is insurance for the scope of work you envisage. Not to scare you, but (in my humble opinion) if your home diy went wrong and caused damage, your home insurance company may deny liability. Their assumption is works are done to a standard, which would include testing and certification. Same thought applies to work in someone else's house.
And the funny thing is @Pete999 you are likely more qualified and better experienced than the freshly qualified sparks they will call in at high hourly rates. For the sake of a liability policy costing less than £100 they are missing a good opportunity there.
There's a handy man on my "patch" who doesn't think any testing is necessary ........................ until things got out of hand and he called me in!
He watched what I did, using my tester to locate the fault - and still doesn't think a tester is necessary ................... dipstick.
Got an on-going one at the moment, a neighbours brother is a 'handyman good with electrics' and wired a small extension. Half of the sockets ceased to operate just after Christmas. I found it wasn't a ring and never had been, and to get at least part of it going as a temp converted two tested legs to 2x 20a radials. Two weeks later half of one of the radials stopped working, found neutral broken somewhere over the ceiling under a flat roof. Not trusting any of it I disconnected the lot and washed my hands of it, they are currently waiting for bruv to return from abroad and fix it.
Good luck with that.
Does your liability insurance cover any Electrical work you carry out?
Do you have access to a multi function tester?
Do you know what certificates are required for the different types of work you are considering doing?
Have you got access to an on site guide or 17th Edition regs book?
have you got any Electrical qualifications?
Do you understand what Equipotential bonding is?
do you know what a TNS, TNCS, TT or PME system is?
lots to think about fella.
Reply to Handyman and Electrical Work in the UK Electrical Forum area at ElectriciansForums.net
Hello, I’ve started a modest handyman business and have come across some electrical obstacles. Up to now I have outsourced work to my electrician...
Just an introduction. I'm James and am based in Sydney. I have an Electrical Engineering background and am heavily involved in DIY electrical work.
Hi all, I just found this forum last night and figured I would post my issue since I can't find much out there with a similar situation. My job...
Hi there : I am just posting to introduce myself, stop lurking (!) and to thank the many sparks who so freely share their expertise on this great...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
