Discuss Hardwiring Microwave in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
Adr Co
Hi
The property i moved into recently has the microwave cable joined to the mains cable within the wall/trunking
It is located within the kitchen units so I am imagining that this cable was originally intended for an oven or other such appliance
The plug was simply cut off the microwave and joined to the mains cable via a simple strip connector
I was wondering if it is safe to install my new microwave the same way?
Thanks for your help in advance
strip connectors are prone to failed contact and/or overheating. any failure could result in the wall becoming "LIVE" and a danger. they should NEVER be buried in walls. also, your plug on the appliance contains a fuse to protect the appliance flex from damage through overload or short circuit. you will not have this protection as you have described how it is at present.
By mains cable I assume you mean some T/E as part of your installation.
Besides flouting more regs than I can think of, there would be no cable clamping on the flex meaning just moving the appliance could result in a bang and the actual flex itself would not be sufficiently protected against overcurrent. Do what Tel said, get someone in to fit a plug and socket, won't be expensive
The mains cable projects about 8" from the wall so the strip connector isnt buried, i would be more comfortable using the plug/fuse as you have suggested though .... would the electrician be able to use the mains cable thats currently there to wire up a new socket? Is this a difficult task?
should be a simple job as long as there are no issues with the wiring. e.g. if fitting a socket, an electrician needs to ensure a few other things before he can test and issue a certificate. like earthing and bonding, presence of RCD protection etc. job could be a simple £60 ish, or could run a lot higher if there are issues. call round a couple of local sparks. quotes are usually free.
Reply to Hardwiring Microwave in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
First time poster here seeking a little advice/confirmation I have spurred off to a fused switch and from there running two 2.5mm cables to the...
So, I'm having grid switches in my new kitchen for things like cooker hood, dishwasher, fridge freezer, integrated microwave etc...and know how to...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
I've been told I need to upgrade the main earth bonding to 16mm. The consumer unit is on the wall adjacent to the externally mounted incoming...
4K
I've been trying to locate anything in the regs that say this can't be done, but can't see anything. Basically I have a 3kw oven on a 4mm T&E...
7K
