Discuss Harmonic distortion causing high loss?? in the UK Electrical Forum area at ElectriciansForums.net
I am busy investigating why my household has an unusually high electricity consumption. Over the past few weeks I have been manually measuring the consumption of many electrical devices in my house (such as the TV, computers, washing machines etc) in order to determine what could be using high amounts of energy. After accounting for all the big energy-consuming devices (and some rough estimates of lights etc), I still have an unaccounted 45kWh of electricity usage.
As I am not sure which devices could possibly still account for this usage, I am starting to think some electricity is leaking somewhere. However before I want to go over all the wiring in my house I wanted to check if perhaps the power quality in my house is bad perhaps accounting for a higher power draw than I am assuming.
In order to determine this I measured the AC voltage from the plug using a resistive voltage divider (and floating the oscilloscope) which showed some distortion (I think). I was wondering whether someone here might know if this distortion is significant and if it could be worth renting a proper harmonic power analyser to further analyse this problem...
Furthermore while doing this experiment, I found that occasionally there was a large voltage spike, but was not sure whether it was a quirk from my oscilloscope.
I look forward to getting some thoughts on this. And if someone has tips on further investigating unexplained electricity usages I am all ears!
Intriguing!
Is your unaccounted usage figure for a day, a week, a billing period!?
Are you using a scope probe on that resistive divider?
I imagine the artifacts you observe may be due to the set-up - the waveform doesn't look that horrendous to me! I have no knowledge of how meters deal with harmonic distortion, but I naively assume they would make a good fist of measuring the power you actually consume, within reason.
Others here will surely know.
If you have a clamp ammeter I would be inclined to monitor the feed and see if the (obviously varying) consumption tallies with your assumptions. Could there be a load you've not accounted for?
I think you would know if something was 'leaking' that much!
What are you using to measure the energy consumption? Beware that many domestic energy monitors do not correctly measure non-unity power-factor loads, whereas suppliers' energy meters do. Therefore with a mixed load a discrepancy between the two is common. With certain low power-factor items such as electronic modules using capacitive droppers in white goods on standby, some energy monitors have been found to be over-read by a factor of 5x.
Leakage is often proposed as a reason for high bills but is rarely significant. Energy dissipated by leakage is manifest as heat and anything over a few watts usually makes itself known. 50W is the heat output of a large soldering iron which would rapidly burn out the insulation of a faulty junction box or cable, but would only add €0.25 per day to the bill if somehow it were able to persist.
Please do not float the scope ground, it's always bad practice. Not only due to the shock risk if the casing becomes live, but leakage from the scope AC power innards to the measurement ground can cause significant errors. I suspect this is part of the cause of the waveform you are seeing. There's no excuse - you have a differential mode available. Connect the two probes to two taps in the divider and set the inputs to invert and add.
Don't forget that impulse voltages can blow your divider to smithereens unless it's rated for Cat III or more. If you just put some resistors together, you did allow a margin on their limiting element voltage, I hope?
If that is in fact the waveform of your mains, yes it is a bit distorted but probably within the capability of the suppliers' meter to measure to rated accuracy. The impact on most domestic load efficiencies would be trivial, so I do not think that is a major player in your presumed excessive bills. At least, it is probably hidden inside the error brackets from your estimating process.
I have seen cases where a non-RCD circuit has a fault to earth that is able to drain several amps but fails to trip the over-current protection (MCB/fuse) due to the modest earth resistance.
This sort of genuine "power missing" case is only likely to be to earth as if it were a fault L-N in a cable, etc, the power density involved would start a fire or cause the initial fault to escalate to a short.
You say "unaccounted 45kWh of electricity usage" but you do not indicate the billing period for this: per day, per month, per quarter, per annum?
45 kWh is roughly £9 and per year is an average of 5.13W which is easily the stand-by power of a satellite TV box, etc. Per month it is 61.6W which is harder to account for, and per day a more worrying 1.8kW and that will make your bill eye-watering expensive!
The unaccounted 45kWh is per week. So that's a bit more than 6kWh per day, so I guess that's around 300W that I am losing which is quite significant.
For the measurement with the oscilloscope I was using probes on a voltage divider with a 10x reduction to stay in a safe region. But yeah I agree that it is a bit dodgy to measure the mains using a scope like this.
The reason why I was a bit sceptical about faults in the metering is that I can (vaguely) remember that there was some scandal a couple of years ago in the Netherlands where electricity companies were deliberately installing meters that measure apparent power. But I can't remember what ended up happening (or whether it was just a big conspiracy theory). Furthermore I can't imagine our power factor is too bad as we do not have a lot of especially inductive/capacitive appliences as far as I am aware...
For now I think I will look into measuring the power consumed for the different groups in the house (perhaps I'll invest in a clamp meter), perhaps I can narrow down a problematic group and focus my investigations there.
All the wiring done in the house is very dodgy (by the previous owners). I've found semi-live neutral wires in the past. Furthermore the neutral wire of the 3-phase wire going into a second distribution box melted at some point. And when it rains hard some circuit breakers randomly trip, perhaps also indicating a leakage somewhere...
I am afraid it might be time to stop ignoring the red flags and start rewiring certain sections of the house...
The weekly usage I have accounted for so-far is shown below, with the total chart amounting to approx 105kWh (per week). If someone has any tips on other big consumers I might have missed let me know :). I measured the power consumption using one of those standard plugin meters.
Yes, that would be observable on any moderate meter.
You can get CAT-III probes but they are not so cheap:
First of all you really, REALLY should be getting that checked out professionally!
At the very least an global IR test (L+N to E at 500V) to see if there are any faults to earth, and more generally all of the circuits tested/inspected for problems. There may be some folk on this forum who are near to you can could give you a sound EICR (electrical installation condition report) as a starting point for any work that is needed. Quite likely they would also identify the problem of any "lost power" in the process. If you can post your town or post code (no further details) then someone might get in contact.
Background to EICR coding can be found in the Best Practice Guide #4 downloadable here:
OK, just seen you are in the Netherlands so probably few folk here are local!
But the same basics apply, get some professional testing done.
Reply to Harmonic distortion causing high loss?? in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone In September 2023 I rented a beautiful 3 bedroom apartment, with all electric supply, no gas powered appliances. I noted down the...
Hello, Not an electrician and I currently live in an apartment building. Over the past few years I have been having abnormal problems with my...
Hi Pretty new here, so not sure if this question goes into this thread I am not an electrician; however, I plan to integrate IOT devices and...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
