Discuss Heat pump diversity calculation question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Lc1
Hi,
When calculating diversity. Does external air conditioning equipment such as heat pumps fall under heating and power in the osg such that you take 100% of the highest then 75% of the remainder?
Hi - just my thoughts, but perhaps keep in mind their use on site. If it's office work space then possibly each morning they will be timeswitched and run flat out till temperature target achieved. This may be why thermostatic heating loads have no diversity allowance (6 and 7 in Table A2 of OSG), just saying.
Reply to Heat pump diversity calculation question in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I've noticed that my UFH pump is not always turning on as soon as the stat & valve calls for heat. This results in hot water passing...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
Hello everyone, I am currently in the process of estimating the electrical demand for a new construction development that will consist of an...
Hi all, taken on a new build project and they have quite a large property with three separate manifolds. I have wired before with one manifold but...
