Discuss HEAT TRACE - What should be used as means of disconnect? in the UK Electrical Forum area at ElectriciansForums.net
why would RCD protection be required, unless it's in a bathroom or similar special location?
All the trace heating supply circuits I’ve came across in existing buildings have not had RCD protection.
BS7671 says that manufacturer's instructions be taken into account, not blindly followed.
Reply to HEAT TRACE - What should be used as means of disconnect? in the UK Electrical Forum area at ElectriciansForums.net
Hi , Wondered if anyone can help , i currently install and test Trace Heating Cable on Mechanical Pipework for Frost protection . Recently our...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
