Discuss heating connections in the UK Electrical Forum area at ElectriciansForums.net
J
jmc1683
so I've got an s plan heating system in 3 story house, separate valve and stat for each floor, then the hot water valve and then another valve for underfloor heating in extension. altogether 5 valves. so this wont work on standard 10 way honeywell junction box right? I'm learning these systems and want to understand them better, please talk me through it a bit and if possible direct me to suitable wiring diagram that would be close to this, i'm looking at the standard s plan, im thinking you would need larger junction box to have each stat operating each valve seperatly?
would suggest looking at the honeywell wiring guide issue 16 the s plan plus shows 3 zone valves one hot water and two heating zones would just need to incorporate a couple more connectors in wiring centre
Use a time guard connection box, loads of room, loads of connectors or even two if it's easier
As said above the same as a 2 x 2 port system with additional valves
spend a bit of time drawing out the wiring and you will see its only basic switching
good luck
Reply to heating connections in the UK Electrical Forum area at ElectriciansForums.net
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
I've pretty much sussed out the wiring for the radiators and underfloor heating, thanks to help from the forum. I do have one more question...
I have not had to do the wiring for a wet underfloor heating system before. I think I started a thread fairly recently and had some very good...
Hi people, I’m new to the forum, first post so here goes. I’m wiring a heating control system and at the moment the customer wants as follows; A...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
