Discuss Heatstrip THE3200r Trips Switch in the DIY Electrical Advice area at ElectriciansForums.net
Our sparky has just installed 2 x Heatstrip THE 3200 strip heaters (13A Max Each) which keep tripping the switches in the power board.
We have checked the cabling (20A Max Each) as well as the Power board (50A) to ensure capacity.
Reading the manual the guide recommends hardwiring the heaters as opposed to a plug and socket.
Could the fact that they have been wired via a plug and socket be causing them to trip, or is this a red herring?
Thanks in advance
what is tripping (MCB/RCD)? and what rating?photo would help.
You’ll have to excuse my ignorance but MCB
can't tellfrom photo. what do they have on the front of the breakers. B16?
Reply to Heatstrip THE3200r Trips Switch in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Our family room is part of an addition built a few years ago. We had an issue with nuisance tripping on an AFCI and the electrician came and...
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
