Discuss Hello can you help me fix my house? in the UK Electrical Forum area at ElectriciansForums.net
Myady1
I dont know much about electrics.
Here is the issue.
Electric tripping (not blowing) consistently after about 1.5 hrs.
We narrowed it down to one of the fuzes on the box. When we turn that off the rest is fine. We have unplugged everything systematically from that line to try and find out what it is but nothing seems to be stopping it from tripping.
Whats on the line is the kitchen, and study, so not the boiler.
What would you look for next? Do we find the cables to check for rat bites? (or would this make it trip instantly? Not worth doing?)
Could it be the box / commercial unit?
We called out an electrician once and he disconnected the outside light that was on that line too, but still tripping, and we cant really affort to get out another one.
If you could help me at all that would be hugely appreciated. My dad wants to pull up the floorboards and check the cables. So any advice if this is a good idea or not, or what you would do. Any help would be great really.
Hi, Thanks for replies.
Yes we did get a sparkie. he said it was on the nutral side, not the live side. Not sure what that means really. And he unplugged the outside light leaving just all the stuff plugged in in the kitchen and study and 1 bedroom on the line which we then turned off. I didnt know that about having to actually unplug them so thats really handy. Ill unplugg everything again and see.
We have had some leaks in the bathroom recently which I thought had been fixed. So if it still trips after I unplug everthing from the socket, does that mean it must be some sort of water in the walls. What does it mean that its neutral? does that mean its an applience? Or could it possibly be water damage still? The fact that it trips after 1 - 2 hours, makes me worry that its water damage which would be very expensive to fix I guess.
Also Im in south wales, near carmarthen. Thanks again
Welcome, What is it that is tripping, RCD, or MCB? Whatever your House sounds like it needs testing by a competent Electrician, did the Electrician carry out any tests, or was it a hit and miss sort of job?
Any idea how old your electrical installation is?
and as @Pete999 says what is actually “tripping”? Post some pics up........but bare in mind it’s nearly Friday evening o_O
.but bare in mind it’s neatly Friday evening
beer oclock for some people ,and wine for the gentry people ,what what .
It's the gray one in the middle that's tripping only. 1991 electrics were done. And the electirican didn't do a full check, we thought it was the outside light at that point.
methink OP should ost his location, may be 1 of us reprobates colud be close and pop over for nominal fee (few pints diesel and a couple gallons beer. , or is that wrong way round? )to investigate
bloody big area is wales. i could only cover the north, anywhere south of wrecsam is bandit country to me.
Reply to Hello can you help me fix my house? in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Hi I have a 3phase shop in a high humidity area in (Hawaii) and I'm having some issues with low voltage on the single phase outlets on the 120v...
