Discuss hellooo from london in the The Welcome Forum area at ElectriciansForums.net
Rundiz
now i have a question that will test one of you
i have a number of dorman smith 32a type b rcbos in one of the buildings where i work, they are in the off position however there is still power out the load side the switch will not stay up at all.
ive put it down to the rcbo defective but ive never seen anything like this before so i thought ide try get a little insight from any of you guy
thanks
i've had MCBs fried so that they won't switch off.
i havnt been able to disconnect or do any testing yet as theres computers on theses circuits so im waiting for the rcbos before we do any of that and i cant see there being any back feed this buildings newly refurbished however i am concerned that the equipment there using on these circuits may be causing the issue as they are labs doing secret stuff lol, all will be revealed soon enough i guess. ive also recomended to split there loads up so there hubs are on seperate circuit
just done a bit of research on ups backfeed seems like thats the only explanation that makes sence cant wait to test it
thanks guy appreciate the help
Watch your fingers when you test, assume every wire could become live at any time. This is one of those issues that could easily result in you getting an unexpected whack off something.
thought ide open this again after investigating this problem there was no back feed from ups the rcbos would not trip under any test and after opening one up up the contacts were welded any thoughts has anyone seen this before just to mention there were 3 rcbos in question
Reply to hellooo from london in the The Welcome Forum area at ElectriciansForums.net
We have a customer in a large office block with all power in the building fed from an Electrak plug in busbar system. Lots of desks, lots of...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
What title says basically. Sorry if this has been posted before but I couldn't find anything. I'm 23, finished a degree in costume a year ago and...
5K
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
