Discuss help 4 nic inspecter in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
carl sparks
hi just want to make a list of things i need ready for the man:D
1 wot docs do i need and where can i get them from
2 wot certs do i need
3 wot do i need off labc
4 wot id do i need
5 wot test instruments do need for him to see
6 wot does he bring with him
7 and finally wot happens at the end of it all:confused::eek:
he cirrus i did but they dont tell u nothing they only ask u 4 payment just like to know wot u need to make sure ive got everything when he comes and not start scrathing my b---s and trying to think of sh-t to make up:D
haha oh ok but if I was paying that much cash out then I make damn sure I am armed with the relevant info in order to prepare myself.
Not gone through the process myself yet but there are plenty on here that have / are so am sure someone will give ya some pointers soon;)
they send all the kinds of stuff out first of all, lots of leaflets telling you about there rules etc, what you need is in amongst all this, have you received anything in the post back from them yet??
  1. BS7671 / osg / 2mill pli / EAWR / part P doc / calbration cert for meter(s) / complaints log / health & safety policy / log of certificate serial numbers issued.
  2. Any certificates that you have issued for the work you are being assessed on.
  3. Nothing ( so far as i know).
  4. Tools & steps.
  5. All that you have used on the work you are being assessed on (make sure they are calbrated)
  6. Forms / note pad / pen / clipboard.
  7. You are asked how you think you've done, then are told that
  • you need a re-visit
  • you are ok but can only be recommended for defined scope
  • you will be recommended for full scope approval.
hi sparkyork i had all the leaflets but it dont tell u where u can get anything from and wot the man looking for and wot to bring with u like steel toe cap boots safety glasses and all the rest of it
is this for domestic installer??
health and safety policy (nic site)
approved part p (google and print is what i did.
HSE memorandum of electricity at work regulations (got mine from company called Seton (google it) they give you a free 30 day account. or whsmiths??)
BS 7671 (if going fully approved)
or on suite guide 17th
method for testing yout test equipment record sheet (have a look at nic site)
customer complaints procedure (nic site)
calibration certificates
minimum 2 million public liablilty
i got me 2360papers out just in case
eal dom installer cert (not sure if this is essential??)
17th edition or 16th (again i didnt have either, but will need to do them for next year)
if you got a major job to show them then you should have a building compliance certificate of your local bc (in my case they werent able to produce one so they used my certs instead)
also your minor job depending on its location will also need labc maybe??
4 wot id do i need
i dont think you need any,although if yo had some little badges made with a nice little picture on it then it will look professional
full set of installation test equipment all leads etc
a suit and tie and black shoes and a clipboard, that he scarily scribbles in or ticks n stuff!
he'll tell you if youve passed or failed, he was only with me for 2 hours, partly cos he said he was off to play golf!
hell leave you with an a4 document explainint that your business is either fully complaint or not.
you then go out and get ****ed.
after 2 weeks if you pass you'll get some more stuff sent out including your nic certificate with company name on etc.
you then log onto nic building control site and create a username, you then wait for an activation code to come thtough (im at this stage now)
thats it me old fruit, take you time make sure you got it all and also id swat up on testing and expected results n what have you. and also swat up on buidling regs youll get some questions on min depth of notches etc and where you drill joists etc
to add as well if your taking him to a bulding site then clearly boots and vest is gonna be sensible as will descent set of test ladders!
cheers easyfox just starting to make a list now of wot ive got and wot have not got wots the thing with the complaints docs where do u get them sort of things from im strating to get lost again all this DOCS:mad:
comlaint forms is on nic site try under downloads. print em out and stick em in a folder with some appropriate dividers here n there.
have you got a date for it yet?? what i would say that is easy said than done cos i was the biggest beatch going when doind mine! but really dont panic, get your docs sorted out which dont take long and put them to one side, then just swat up on testing and the building regs etc oh and a bitta 17th stuff as well
sparkyork i will let u no how im doing and when he is comeing cheers again mate i hope i can help u one day but lt looks like ur on your way now oh and well done for passing cheers aswell easyfox wot a great site this is
youll be fine mate, the only place ill be goin at the minute is jail if i dont stop doing work with poor main equip' bonding!
yeah it is pretty good site this, there are alot of very knowledgable people here
Reply to help 4 nic inspecter in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
Generally speaking CLEAR heat-shrink tends to be a 2:1 or 3:1 shrunk size ratio, 4:1 is around but less common... has anyone ever found a source...
