A
AdamG1991
Hi everyone, i'm doing my 2330 practical exam tomorrow and would really appreciate any tips as i am a little bit nervous about it (i usually never get nervous about exams)
in case some of you don't know, what i gotta do is install a socket ring with 2 sockets and an fcu and a two way lighting circuit from one consumer unit with the incoming power from s.w.a, it will be running in singles through p.v.c trunking,steel conduit(sockets),plastic conduit(lighting) and clipped direct between the two switches one of which is on brick.
The wiring is fine i am 100 percent on that i am only a little bit worried about getting the steel conduit right without messing up and wasting any and the fitting of the s.w.a as i've only used s.w.a once before so any tips on using that would be greatly appreciated.
