Discuss Help any sky fitters in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
B
beaver74
Hi all
I have just gone head over foot down a set of stairs and I pulled a extension plug apart
it has SKY TV DO NOT UNPLUG
at the far end of the plug is a phone point and a small conection possible data.
at the far end the phone work fine.
at the plug end which plugs into the main phone point there are 2 cores not connected(or have they pulled out???)
does any one know if the phone point at the end of the extension lead are seperate or the unterminated core were like it befor I pulled them
cheers
cheer I did actualy turn on the router and search for a WIFI network, check all networks and then turn router off and when the customers router turn off a WIFI net work disipeared so I ussume it is good to go
thanks for in put
Seeing a wifi network can be done without it being plugged into the phone socket, its a case of seeing the wifi network and is it connected to the internet?
As posted above, only one pair is required.
Reply to Help any sky fitters in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Iv been asked to wire a separator (portable to go to different farms and separate water from slurry) to a 3phase 40 kva generator. The separator...
  • Locked
5K
So Dad's Old condensate pump went kaput (screeching like a banshee, float valve sticking and wouldn't shut off due to said sticky float valve but...
