Discuss Help choosing wire sizes in the UK Electrical Forum area at ElectriciansForums.net
Hello!
I have a 320 amp service (400 amps) in a main panel. I want to create a subpanel 1,000 feet away with a 200 amp service there. Can someone tell me what size wires to run, if aluminum or copper, and how many wires? For, say a 3% voltage drop? How would you do it?
Thank you!
Hello!
Thank you!
Employ someone that is competent. to do the install and design for you
I will be employing someone to help. But I don't need to be up-charged for the materials. Thats why I would like to find out what folks recommend for cable sizing.
The site, the incoming supply characteristics, the cable run and the distribution requirements will need assessing by a professional electrician to determine what type and size of cable is required. This will be an expensive run of cable and should be designed properly.
Hello!
Thank you!
I’ll tell you # 3/0 copper to each panel. You will need 2 # 3/0 for your hots, one 3/0 for your neutral and one # 6 ground
Reply to Help choosing wire sizes in the UK Electrical Forum area at ElectriciansForums.net
I'm starting a new construction single-family residence, I know with the 2020 NEC they require an emergency disconnect on the exterior of the...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi, new member here with a question. I am adding a 100 amp subpanel to my 200 amp main panel. They are next to each other and recessed in wall...
Greetings, I'm a EE and have installed many electrical systems but am now dealing with my first large 3PH install on our property. I'm not...
I’m planning to run an electrical sub-panel to my detached garage (about 150’ away) and run it off my 200 amp home panel. I live out in the...
