Discuss Help finding old MCBs in the UK Electrical Forum area at ElectriciansForums.net
LewisM
Hello, does anybody know where I can get hold of and old VOLEX MCB in this style??? 20A
https://i.Upload the image directly to the thread.com/zISueG0h.jpg
Thanks Lewis
Aye. Neweys should be able to help.
As a note.
Volex aren't treated with the same distain they used to be years ago, although they are now produced abroad. All the accessories used to be dire....'Ward and Goldstone crap', as we used to know them in the eighties. The firm's (W+G) headquarters were in Salford.
Electric center also used to stock them.
I was just about to ask why there are no socket circuits on the board but then I spotted it way off to the right.
Yeah there is one ring well not actually a ring as there is no continuity, hence why I want a 20AMCB only went there to add a socket and chase in two, went to test and of course no ring continuity, checked all accessibile connections and customer doesn't want floors pulling up etc so only thing I can do is derate the breaker so it's a tad better.
Won't you need an rcbo then Lewis rather than a mcb.
Reply to Help finding old MCBs in the UK Electrical Forum area at ElectriciansForums.net
Hello sparkles, I have a question in relation to sequencing the RCDs and MCBs in the CU. I called an electrician to come to my house and upgrade...
Hello, 1st time post from an amateur. I have some old Habitat decorative lights that are powered by a transformer. There seems to be a break in...
Hi I'm trying to find if I have a fault in these to brakers of in the lines. The 32A braker leads as far as I know only to a junction box that use...
Hi does anyone know where I can source any larger round grommets ? I will be drilling a hole in 100 × 100 trunking so guess around 75mm hole. I've...
Hi guys, I don’t really know where to post this, sorry if it’s in the wrong place. After posting a thread about old lead sheathed cable in my...
