Discuss Help, fire alarm system. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
O
optician
Need to test a 3 phase board but have a fire alarm system/board off one of the phases, before the main board, which says do not switch off.
Can I leave the fire system board on and perform all live tests on the 3 phase board with out affecting the fire system?
Typically the only reason they tell you to not switch them off is because they don't want you to leave them off, run the battery flat, then have no protection. The absolute worst thing that might happen is that you'll put a power failure event in the event log, if so equipped. No big deal, as long as you remember to turn the thing back on. No different than if you had a power failure.
Reply to Help, fire alarm system. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
