C
chrisgc
Hi all,
My brother called me today to ask if I would like to do some work for him at his house.
I have to meet him tomorrow but basically what he said he want is the following:
Existing switches to be relocated to a higher position as they are too low based on the regs (this was advice from his architect).
Anyway what I am after help with is the following:
1) What do I use to extend the existing wire (as there is not enough slack to use existing) as I will need to take out existing back box then join old cable to new cable and then re-plaster over where current location is and can't use junction box as it wont be accessable after plastering?
2) Is it ok to join old colour existing cable with new colour cable?
3) Can someone maybe also give me a list of things I will possibly need, ie. conduit, clips etc?
4) Best way to chase out wall without a wall chaser?
5) As I am not sure if I am making good and thus not sure if switch plates need putting on after I have installed cable - what is the best way to make sure that the new exposed cables are covered/terminated to prevent anyone touching the live wires?
6) Finally and most importantly - what tests do i carry out on the said circuit BEFORE I even make a start on the above? ie. To check for any potential faults which may need putting right beforehand?
Any help would be really appreciated.
Chris
Chris
