Discuss Help identifiying a cable please in the UK Electrical Forum area at ElectriciansForums.net
Ross1
Im carrying out a PIR, there is a 3 core (what appears to be solid aluminium armoured) cable supplying one of the single phase DB`s. the solid cores are almost triangular in shape, colours of cores are RYB. The csa looks anywhere between 16mm and 25mm/sq.
Any ideas on cable type and so I can find out the ccc.
Aluminium SWA probably. Don't think j the armour will be ally.
Picture would be good, have, or can you get a decent view of the outer PVC sheath, might give you an indication of the size on it.
measure 1 side of the triangle. say, it's 8.0mm. square it =64sq.mm, then halve it = 32sq.mm csa. schoolboy maths. :D:D:D.
it may be imperial so no exact match in millipedes.
Yes but is it a right angled triangular conductor, if so you could use Pythagoras's theorem, crikey must be the Wine I even spelt that lot right, except for spelt maybe.
Yes but is it an equilateral triangular conductor, if so you could use Pythagoras's theorem, crikey must be the Wine I even spilt that lot right, except for spelt maybe.
corrected that for you.
Reply to Help identifiying a cable please in the UK Electrical Forum area at ElectriciansForums.net
Background: I am not an electrician, I am a retired professional engineer high power broadcast transmitter design , but am dabbling outside my...
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
Hi everyone, A local pub is changing one of there function rooms in to a cafe, there plan was to have all gas equipment so i done the cable calcs...
