Discuss Help identifying part needed. Box missing lid. in the UK Electrical Forum area at ElectriciansForums.net
Paul92688
I am getting my dads house ready for sale. I need to fix a few things before it is listed. This piece needs a cover and I am not sure where to turn. No one at the hardware store to be found for help. Possibly you can help
Thanks!!!
Paul
Thanks!!!
Paul
Paul did you go to Home Depot or Lowe’s to find a blank cover. If you can’t find it there go to an electrical parts house. Worst case you could possibly make a cover. Is that box plastic
Thanks for the reply. I went to Lowes, couldnt find the part and there was no help available. At this Lowes, probably not because of the Pandemic as there is seldom help. I may try and seek out a specialty store.
Paul
[automerge]1589986561[/automerge]
might be easier ( if OP is competent) to undo joins, marking what's what, and drill and fit a new box.
Competent with the electric. Not so crazy about the plumbing aspect. Will play with electricity all day long. Anything to do with pipes ( conduit ) no thanks.
I may have to cut the box off and try to put a new one on ( one that has a closing part )
Paul
Paul
Paul
If that box is metal it looks like a box used for highly explosive areas. I think your best is to try an electrical parts house
Pool light junction box, the cord in the center goes to the underwater light, that cover would be a electrical supply house item & would have to buy the whole J-box. If the pool is gone might be a good idea to make it safe and get rid of it, fewer questions from HI's (idiot home inspectors), when selling.
Reply to Help identifying part needed. Box missing lid. in the UK Electrical Forum area at ElectriciansForums.net
Hi all I have a small DC motor that I pulled off from an ABS car module and need help identifying some parts in order to hopefully rebuild it. 1...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
Hello, I am trying to replace some lights in my walk in closet, I began with light 2 and before realizing how confusing this could get, I forgot...
Hi guys, I could use your expertise. I have an old automatic pool cover, kept in storage for 30+ years, in good condition, and worked well last...
