Discuss help installing nest. 3rd gen, zonal. in the Central Heating Systems area at ElectriciansForums.net
hi, bought a nest term hoping it would be easy enough to install
but what do you know, having a few issues
i have 2 zones and hot water tank, but only installing one nest (for now)
so wanted to replace current timer with heatlink. Took timer off wall and cant figure out what to do with wire 7 (heating 2)
as you need 2 heatlinks for zonal install on nest, what can i do with this wire if only installing one heatlink?
plus if i actually buy another heatlink (in future) for 2nd zone, how do i power it? there is only 1 power for this timer so how to power 2nd one?
2nd question
i would like to replace current thermo with Nest, but when i take it off wall it looks like 240v wires feeding it, which i understand will blow the nest.
any way round this? or will i just have to have Nest wireless a nd plugged into wall somewhere?
attached pics below
thanks for any help
You have three timed outputs there do you know what each one controls? I would find out and label before you start also conductors need sleeving ie.blue for neutral so you don't get confused what they all do.
I don’t like that grey in terminal 3, should be moved to the other side of the screw, too close to the neutral for my liking.
Also wondering where the other blue conductor has gone?
What other blue conductor?
Dunno why they have put 3 core and earth to the stat but not bothered to actually connect the 3rd core to the Neutral in the stat.
Reply to help installing nest. 3rd gen, zonal. in the Central Heating Systems area at ElectriciansForums.net
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
Hi guys, Do you know if I can install a Nest E with the heat link in the airing cupboard as opposed to the room stat position? System is a S plan...
Hi all, I have an issue which i assume is due to incorrect wiring, but hoping someone might be able help me to fix it myself. My setup is a Nest...
