Discuss Help looking for a breaker in the Canada area at ElectriciansForums.net
can anyone tell me where i can acquire a faz g50 amp three phase breaker? :)
Just a quote from the KM site. Looks like they only make the FAZ type up to 40A
Moeller's FAZ Branch Circuit Breakers are available in one, two and three-pole configurations with 20 different current ratings ranging from 0.5 to 40A. All breakers are available in both C and D tripping curves, providing protection for applications where medium and high levels of inrush are expected.
I've got loads of 50A 3P breakers but no KM ones:)
the g50amp has connections further forward and no other makes line up with buzzbar had to cut buzzbar link out with a chint to get machine running but want put back to original setup
Reply to Help looking for a breaker in the Canada area at ElectriciansForums.net
I need to replace two AFCI breakers on our main circuit panel. I have replaced and added breakers to our sub-panel several years ago. When I...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
Good afternoon - we're considering adding an additional breaker to our "main service panel" which is where the meter is located. That panel has 6...
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
Hi all, I’m looking for advice I removed the tamper tags on my three phase power mains to install a new circuit breaker. It disconnected the...
