Discuss Help needed for a touch lamp in the Lighting Forum area at ElectriciansForums.net
Robbyg
Hey :)
I'm Rob and new to this forum. I have designed a wooden touch lamp using edison bulbs (incandescent) nothing new here I know. What I'm having trouble with is sorting out a problem where when the bulb fails the power surge takes out or blows the thyristor on the touch circuit.
Normally not a problem on cheaper lamps as they are throw away but the one i've designed is going to be a higher end product and I don't like the idea of lots of possible returns after a blown bulb scenario.
I've looked at a MOV in the circuit to take the surge but don't really know enough about them of whether this is the best and cheapest way of doing it, any help I would appreciate a lot.
thanks, Rob
The best way to reduce the chance of the thyristor blowing
is to use a larger thyristor, so use a 15A, instead of a 6A.
At the highest possible voltage, so use a 6 or 700 volt thyristor
rather than the bog standard 400v versions.
Thanks for the reply :) is there nothing that can be placed in the line between the touch lamp module and bulb to sort it? I’m trying not to have to alter the board from standard as they are ce approved and the added time also soldering a new thyristor in ect
Reply to Help needed for a touch lamp in the Lighting Forum area at ElectriciansForums.net
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hey all. New here and new to 3 phase. I had some electric experience on set in Los Angeles as a gaffer for a couple of years, but it was mainly...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
I'm moving a socket installed on a lighting circuit (installed by previous owner who was a professional electrician so I assume he knew what he...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
