Discuss help needed to bypass touch switch on led light in the DIY Electrical Advice area at ElectriciansForums.net
jonbla
I want to bypass the touch sensor on this aquarium light on the wrg side so i can connect it to a mechanical timer. Any help appreciated please see attached picture.50165
Welcome to the forum mate.
Can you take a pic of the wires going to the existing switch.
Thank you for your reply the switches are encased in the end section i will attatch a picture but taking it apart doesnt help with the view there is a singular wire going to 2 switches the white on the left is the only one i need to work the second goes to a blue row of Leds which are not important.
This was my first call, the part number returns no results as its a chinese ebay special.
Probably get shot for this but email someone like bigclivedotcom, he's always taking Chinese specials apart, might be able to help you.
Just replace the whole unit for a suitable driver.
Do you know what type of leds they are?
If you can identify the + & - I would be inclined to replace the touch controls with a 12v driver
Reply to help needed to bypass touch switch on led light in the DIY Electrical Advice area at ElectriciansForums.net
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
