Discuss Help needed with 3 phase! in the Canada area at ElectriciansForums.net
dnsltd
I bought into a sunbed business last year, for my partner and the electrics are a shower of ****e....there isa problem with the ampageanddespite the fact the shop does need a larger supply, we can run approx 80% on what we have....which at the moment is a better option than paying e-on loads of cash to upgrade the supply.
Anyway, the shop below us (where the meter is - which we own) is not ours, and access is a nightmare. Can we request the meter to be relocated FOC into our premises?
Bear with me now, as i am being explained the following via phone....
There is a main isolator from the incoming mains. Then the meter. Then a 2nd isolator, contating three fuses (3 phase obv) all rated @ 30A :confused:. This has been bul****ted / bodged to 90A via 3 x 30A fusewires...nice! then off we go into our premises and a 3 phase board.
The 2nd isolator has rotted / burnt away over time (Obv the connections we're rating at less than the fuse wire!) so we now have a phase down. I am planning on replacing the isolator, then installing a 2nd in line in our shop so any future issues can be resolved inhouse. What i need to know asap is what cable will be feeding the burnt isolator if they were 30A fuses (16mm meter tails?)? Why is the board trip's not isolating firstly? I appreciate this is as difficult for you to answer as it is for you to understand!
The shop is 3 hrs from me so it's not a matter of poppingto see for myself!
Any help appreciated!
Craig
I'd agree, but trouble is bank holiday, and all that! I need to drive up there now and see what's going on and sort it if possible. Unless tehre's any sparks in Mansfield who fancy some work for a fair price!
Hi ,
I think you first course of action should be to replace the defective fittings first ,even if only as a tempory measure ,then with a sensable load applied at least the place shouldnt burn down!
then you can investigate how to upgrade to accomodate your sumbeds ,also if the public are using the premisis ,i would consider closing untill the remedial work is done at least
im not trying to be negative ,but it does sound like a accident waiting to happen
all the best with it
All sorted now :) 2 x new isolator's, and was has been installed in our shop so the first thing to trip will be on our premises.
One thing i don't understand though. Is when we overpower the incoming supply (Which i am told is 74kvA (Our 5 beds use 72kvA apparently when all in full use)) it blows the 100A incoming fuses, rather than trip the breakers which are rated at 25A (3 ph). Why is that??
Cheers
Cheers
IT might not be a problem ,now the defective isolators are replaced ,with a phase down and burnt out connections all sort of strange things happen:eek:
are the are the sunbeds single phase ,if they are it might be worth asking your sparks to test the power factor ,and dont turn them all on in one go from the main isolator ,the inrush will affect the supply fuses not the 32a ones ,maybee thats what happened
#Glad you took the advise and got it done quick
all the best with it all:)
Reply to Help needed with 3 phase! in the Canada area at ElectriciansForums.net
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
