L
LlandrilloSpark
Fella’s I need your opinions on what codes you would give the following items on a PIR
A. Ceiling rose – supply cable which emerges from the plasterboard is 0.75mm two core, so no earth provision readily available without floorboards up.
B. Shower – water inlet on the side has a hole i can stick my index finger in so its a breach of IP codes and access to live parts (1?)
C. Main Bonding Conductor – For the gas not within 1m of the incoming gas supply, more like 3m
D. Supply cable outer sheath not bought into various patress and ceiling roses.
Cheers in advance for any suggestions
