Discuss Help needed with repair of an Enecsys SMI480-60 Solar inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello,
i am trying to repair an Enecsys SMI 480-60 Solar inverter.
I was looking for a schematic on the internet for quit a long time and finally found a schematic on this forum wich is very great.
This thread: Enecsys 480W schematic - https://www.electriciansforums.net/threads/enecsys-480w-schematic.150960/
I inspected the unit en found no burned components, the fuse is ok and there are no short-circuited power mosfets.
This inverter behaves as follows when it is connected to the 220 volts and the solar panels are connected:
  • on a properly functioning inverter, the yield of these panels is approximately 31 watts just before conversion;
  • on the enecsys inverter everything stays at 0 for about 2 minutes;
  • after about 2 minutes, my power meter indicates 2 watts as yield (or decrease) and about 41 VA (apparent power);
  • shortly afterwards everything goes back to 0 and it stays that way.
It looks like the DC circuit is okay and there is an error somewhere that shuts things down.
I hope someone can point me in a direction to track down and fix this error?
Reply to Help needed with repair of an Enecsys SMI480-60 Solar inverter in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I am a retired Electrician and started looking at Solar Power, (Black Magic to me), after much reading of "How To", I decided to build myself a...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Hi all, I hope you can help me please. I had solar system installed nearly 2 months ago and my installer turned out to be cowboy despite having...
5K
Good Morning All! Always appreciate reading the great ideas and conversations in the forums, and now actually have a chance to ask a question...
Hi guys, I am new to the forum so be nice! I used to install solar PV systems back when the tariffs were still good, and I've never had to go...
5K
