Discuss Help please with wiring in the DIY Electrical Advice area at ElectriciansForums.net
Good night to all I need a bit of help with wiring to led weatherproof light fixtures. I bought them today and none of the 2 is lighting up. So here what I did I place the red wire to live, black wire to neutral and ground wire to ground like I normally do with fluorescent lights but they are not coming on. Below are pictures of both fixtures
Could do with some sleve around your ground wire.
Have you plugged the led strip into the fitting? Often they are not connected on delivery.
Have you. checked the voltage coming in to the fitting?
first thing to check is there power getting to the fittings ? is there a fuse in the fuse holder shown in the picture ?is the fuse ok ?
Reply to Help please with wiring in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
Hi, I am installing a new bathroom fan. We had an electrician who ran 14/3 into a junction box. The black feeds a led light and the red was...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
