Discuss Help please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
gunny
I have just changed a consumer unit and when i put any appliance on in the kitchen it trips the rcd i have done all the tests on the circuit and can't find a fault,any suggestions as it is driving me insane !!!!!!!
Either you have crossed the neutrals between the RCD's in the CU, you have a neutral in the wrong place in the CU or a faulty appliance.
Hi.
Either a dodgy appliance, or crossed neutrals in the neutral bars in the D.B
We could be bloody twins!!!!!!!!!!!!!!^^^^^^^^^^^^^^
Reply to Help please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
