A
a1pacino
I am trying to wire some motion sensors in parallel at each end of a corridor at work.There are 6 lights that are connected to this circuit via small plugs. I have got one sensor which work's by connecting it to feed at IN terminal and connecting OUT terminal to closest light. Doing this makes the whole corridor's lighting work via this motion sensor. This is where I have drawn a blank as I have connected this to the sensor at other end of corridor and power is at the sensor but it does not turn the light's on like the sensor at front end of corridor.I know it's probably something blatantly obvious I must be missing but if anyone can spell it out like a 'for dummie's" manner it will hopefully remove the confusion and mental block! i rang the wholesaler and he said that 2 sensors should work on same circuit if wired in parallel.I finished college a couple of year's back and I am already getting rusty! many thanks in advanceWet Fish
