Leccy monster
- Reaction score
- 0
Hello
I'm trying to wire a light. I have a single pole switch and then a ballast and finnaly the lamp.
The symbols on the ballast show where to plug in the earth but the other 2 connections have the same symbol so which one should be live and neutral? (See pic)
The second pic shows the wiring diagram on the ballast to the light bulb. It shows connections 1, 2, 3 and 4 so far so good unfortunately the light fitting has 6 connections see (3rd pic) so I'm confused as how I'm supposed to know which wire connects to which connector. Any help is much appreciated thanks.
